B16 Head Gasket Help
what size gasket should i use for a .25mm bore i cant seem to find one at 81.25mm help please? (have ctr .25 oversized pistons)
Re: B16 Head Gasket Help
oem should be fine. the oem gasket uses a tad bit of clearance on the inside diameter of the cylinder walls and .25 isnt all that much.
i used an oem gasket on my oversized pistons.
yeah i was told oem was fine by my shop teacher today. its my first build im learning its a lot more harder than i originaly thought
well first off its .02" or .025" over which will make it 81.5mm bore. not 81.25 bore. therefor you need a 81.5mm gasket. if you had a smaller gasket think about what that will do to the flow...not good.
since ctr pistons only come from japan and are only used in civic type r motors, would'nt you think that they would use the metric system? hence, a .25mm oversized piston would still be .25mm over, not converted to hundredths of an inch like the standard system.
well shieettttt i was assuming cause most of the time .020 over is usually in inches not mm. so ya i guess stock bore hg will work just fine.
Eghatchgsr8
09-19-2014 02:24 PM
97CTR
14
07-18-2004 01:47 PM
BlackGSR
02-26-2002 06:52 AM
