need help with my b16!!!! please
i have a b16 sir block with a ctr head or well what the guy told me with a real itr tranny i know thats real ha but one how can you forsure tell if its ctr and 2 well sometimes my car likes to randomly stall after i start it up and just let it idle and sometimes ill be driving and my car just starts dying and has no power, like you push on the gas and nothing happens doesnt rev or anything? why is that. i have a stockd series cat with the b series motor with a skunk 2 exhaust. sometimes after it dies and i try to start it up it'll click but wont start then after i stop tryin to crank it over it make this weird noise out of intake, i just thought it could be a clogged injector. ha yeah i know a lot of problems i knew it would be a turd when i bought it but i love eg si's so im just waiting to drop in the k20a r ha. not sure if it would make a difference but i also have 370 rc injectors but if someone could help me it would be very much appreciated ha
Re: need help with my b16!!!! please
my cel isnt on its got a stock fuel pump on it to. when i take my cat off and run it out the header it doesnt stall or anything so im taking the cat off to hollow it out tomorrow to see if maybe its just getting clogged causing all that back pressure to **** up the engine or someting
i just need to know the stuff i need to check ha so i can just start checking everything on thi turd 16 i just need this car to drive til i get the rest of my parts for the swap
check your fuel pressure. could be a clogged fuel filter and, or a failing fuel pump. or clogged cat. and with 370 inj. you are probably running super rich, which will take its toll on the cat. give it a shot.
could my msd coil be not working properly also? because it just randomly started messing up... what tool do i use to check it, i have the msd blaster too
well i would check the msd coil. i had a similar problem on my h22 swap, and i replaced the coil and it fixed it. so just my .02 cents, it might be somthing to look at.
