SI ttranny problem
SI ttranny problem
94 hatch
d15b7
putting si tranny on it
one problem....the clutch pump or valve thats on the tranny..that metal piece doesnt feel like its touching the clutch...do i have to take the clutch out first and put it in the tranny before i put the tranny on the motor?? help please
d15b7
Re: SI ttranny problem
Did the Si tranny come with a clutch fork? The valve thingy is called a clutch slave and it should be pressing against the clutch fork. When you push the clutch pedal, the piston in the slave pushes against the fork, which is mounted on a ball pivot, and the other end of the fork pushes on the clutch release bearing.
It sounds like you may be missing a part or something is not installed correctly.
no i got the clutch fork i got all the parts its just im not putting em on the right way,like im 100% sure i have everything but do you have to take the clutch off in order to put a tranny on?? like do i take the tranny off and then the clutch?
no. you should never have to remove the clutch to replace a tranny, just leave it on the motor.
post a pic, you probully have something on wrong,
im a little confused, on what you mean, its impossible to remove the clutch without the tranny off, you just cant. again, you shouldnt even have to touch the clutch to swap a tranny,
thats not possible.
the throwout bearing holds the fork in place, but he may have it in back words,
when we swapped a b20 into my friends dc4, one of our friends had a brain fart or somthing put it in wrong, and it didnt sit right, or want to move up and down, and after about a half hour of messing with it, it broke, then we realized after some sleep and a new one what was wrong, swaps at 3am lol what can i say
Johnny Cochran
05-22-2006 12:40 AM
CimorelliCRX
12-15-2002 04:02 AM
