Headgasket for b16a2
What is my best, should I get an OEM headgasket or an aftermarket. If aftermarket what should I get.
Mine has a small leak and im getting it replaced tomarrow.
Just need some input.
Re: Headgasket for b16a2
Its not stock, it has some bolt ons. Im gonna go with a Cometic MLS Headgasket, its stronger than oem and just like 20 bucks more expensive.
Bro I have alot of buddies that recommend to go comitec. Im going to be lowering the compression of the motor to 9:1 and adding a Precision 6262 Turbo build on it, custom built kit in the next couple of months so I need a stronger gasket.
you can get a cometic one that creates lower compression. if you want to keep it the same just get a Fel-Pro Gasket. Thats what I use and its a built and boosted motor. Hasnt failed on me. I few other people I know use Fel-Pro also and no problems with any of them.
i recently did my hg with a fel-pro hg and it falied on me =[ i must not be doing it right then huh lol....
aftermarket, b16a2, b16aa2, cometic, compression, diy, felpro, gasket, head, headgasket, lower, oem, part, repair, stock
