I need help fixing a few things...
So I bought a used 1997 Honda civic lx and need some help with a few problems I've found with the car.
First, broken fuel gauge says my tank is always full...how is that fixed?
Second, how do you open a door that doesn't open from the inside OR the outside?
Re: I need help fixing a few things...
First thing could be 3 things, the cluster, the wiring or the sensor. Check those 3.
Check the service manual for more detail: http://www.spoonertuner.com/manuals
2nd: there are tools available that you can stick through your window moldings and pull the leverage with. Kinda like fishing lol. I have no idea what its called in the US however.
I'll be interested to hear what the solution is for the door problem.
For fuel gauge problem:
1) Remove cluster
2) Unplug only cluster connector B
3) Turn ignition switch to ON(II) to see whether gas gauge needle drops. If needle does not drop, then the cluster or gauge is bad. If it drops, then I'll post additional information for troubleshooting the sending unit circuit.
1) Remove cluster
correct...i unplugged ONLY cluster B, the one on the top, and turned the car into the on position with no movement at all.
if your door doesn't open from the inside or out, take the panel off and reach in and pull the lever yourself. or find a door diagram and slimjim it open.
So how do I got about replacing the cluster then? And as far as with the door I can't open it which means I can't take the side panel off
1. Take out cluster
2. Put in new cluster
Jk
I guess you can pop the door panel off with the door closed, but it'll have to bend a bit
Jk
And if it's the gauge assembly do I just have to get one of those from a Honda dealership? I'm just starting to get into the whole fixing cars up thing so sorry for all the noob questions...
bokals
05-15-2006 07:11 PM
vmm
04-18-2005 04:05 PM
