b16 head!?!?
b16 head!?!?
ok so i snapped my timing belt and im pretty sure i bent a valve im doing a compression test soon but im wondering if it is bent..what should i do its a JDM b16a head with cams but if its ****ed and unfixable what are good heads b18's possibly ls/vtec? or just get a stock b16a head and swap out my cams..
Re: b16 head!?!?
I'm pretty sure you bent a valve too. I bent 2, in a h22.
Of course the best head is the Type-R since it comes mildly ported and polished from the factory and has a much stronger valvetrain. The GSR has smaller combustion chambers which will add roughly 0.3 to your compression ratio. This sounds like a good time to plan out a build.
Although my old H22 has two bent valves, the head was in perfect shape, so I just replaced the valves and kept the head.
baynedo
Mid-Atlantic (Sales)
05-27-2011 01:55 PM
Superdragr45
23
07-21-2005 12:03 AM
