Cluster and corner lights wont work
94 honda civic ex 2dr
i recently re installed some hids to my car everything was working perfect.Last light i turned the car on and the cluster light is out the cluster works fine just the light is out and as well the corners the blinkers work just dont light up when lights are on or if i have turned up to parker lights dont know anyone please shed some light !!
Re: Cluster and corner lights wont work
Somebody just put the wrong fuse in, but this would not prevent the lights from working if the 15A fuse is actually good. Swap a known good 10A fuse into the fuse 19 slot to see if the light work.
I had a similar problem with my 96 hatch after I ripped the dash all apart. It turned out to be my hazard switch wasn't plugged in all the way. Something about it completing the circuit I assume.
IDK if this will help as I'm unsure of how similar the wiring is from the EGs to the EKs.
Good luck.
Good luck.
okay everything works thats weird but thanks guys !!!!
next questions both of my doors dont sit in flush like the top corner side budges out
Okay so i change the fuse to a good brand new 10a fuse still the corner and cluster lights dont stay on they turn on but while driving for few mins they shut off!
SiR HatchAlot
03-28-2004 09:31 AM
