Help b16/b18 swap into my jdm vxi d15b7 sol!!
I want to drop a b18c4 or a b16a2 into my sol, can i use the d15b7 hubs with the b16/b18 axles??
Also can i put larger discs onto the d15b7 hubs or do i have to change them????
The part list i have so far is :-
b16/18 engine + gearbox
axles/driveshafts
Engine loom
header
mounts
radiator
gear linkages
anything else??
thanks kevin
axles/driveshafts
Engine loom
header
mounts
radiator
gear linkages
anything else??
thanks kevin
Re: Help b16/b18 swap into my jdm vxi d15b7 sol!!
yes you can use the b16/b18 axles in your b7's hubs not sure bout the brakes though and i belive your list is pretty complete besides the ecu, and depending on the year of your b series motor you may be able to reuse the stock b7's harness
hondatuner020
12
12-27-2007 06:32 AM
