My friend dident gap his rings
Hey H-T
my friend ryan just got done rebuilding his b16 and he dident gap his rings. What im wondering is whats going to happen to his motor. He has only put 10 miles on it and was wondering how much damage he has done if any so far. He realy dosent want to rebuild the whole thing again but i know he has to. Whats going to happen to his motor if he dosent rebuild asap.
Sorry about the ramble
Eddie
Eddie
I'm not Rick!
Re: My friend dident gap his rings
scoring
everything goes out of balance
rattle/knock
burn oil, smoke etc.
but maybe he hit the lottery and had it just right..tell him to just ride it out
rattle/knock
well depending on what rings he bought id say hes ok. i bought oem rings with i rebuilt my b16. and they here gapped perfectly already. which i figured htey would be.
Due to variances in pistons, the bores may have to be bored different diameters, so that would effect the gap of the rings. Like .001 larger bore would result in .003 larger gap. I think someone here might have even said that.
ya if they where oem rings id say hes fine. you gotta figure as long as everything was fine, ur using ur oem pistons, oem rings should fit just fine. i cant see a jap checking every ring on every motor honda makes everyday!
I put JE rings in my d16 and they were within specs. All I did to the block was hone it. I also rebuilt a d15 only honed it and used npr rings and they were within spec.
1 question did your friend install JE pistons? Reason I ask is the JE rings I got were thicker than OEM rings to match the JE forged pistons I ordered. I'm not sure if JE makes OEM sized rings of not.
