What ECU is meant for a 96 b18b non vtec engine?
just like the title says....im wondering what ECU comes stock in a 96 integra ls? i know the OBD code is OBD2a. i have a p28....and my bay is wired for vtec, but i have the non vtec engine. and id like to get the right ECU while im deciding on what to do with my car...which is a 93 civic cx
Re: What ECU is meant for a 96 b18b non vtec engine?
Seagull Management
It'll throw a CEL, but i'm not sure if it will affect driveability or not. With the OBD1 versions it was easy to convert them to a manual, as far as I know it can't be done with OBD2 ECUs.
thanks for all the information. so the way i figure it now...corect me if im worng...if im running the p28 ecu, and my engine harness is a vtec one...and my underdash harnesss is all spliced into...meaning the ecu harness is all taped up and spliced and cut (which it is)....my car runs liek ****...
so..if i find an underdash harness out of any 92-95 civic...and i install my non vtec harness, then i should be able to hook up a non vtec ecu directly to the 92-95 civic harness. am i correct?
na it has to be manual!that why ur getting the idle issues!get new harness dude splicing is bad!!auto ecu runs richer and idles high and a bit boucy when i ran it in my car.
Seagull Management
Basically yeah, Your best bet is to pull the harness from a '92 CX hatch, any '94 - '95 civic (except VX) or any '92 - '95 EX/Si. Make sure the harness comes from a 5 speed civic. It wasn't mentioned in this thread the type of car the engine was in, now that we know its in a 5th gen civic, i'm going to retract some earlier information. Either get an OBD1 PR4/P74/P75 ECU ('92 - '95 Integra) or use a P06 from a '92 - '95 civic DX/LX chipped for a B18B.
well if it used to work perfect and then it all just went wrong lol,then it could be the spliced wires.there is so much that could go wrong with spliced ecu wires.u can solder the wires up if u cant buy the new harness right now.you would have to buy a solder though lol.
the throttle body "rotor"thing is suppose to snap back back then then stop at one point when the throttle body is closed.are u saying that it gets stuck before the throttle body closes?then u probably need a new tb.itll probably be like 20 bucks at a junkyard.im 16 and i swaped my motor at 15 so i know wat u mean,dont sell it haha.
mistaashby12
11
08-04-2008 07:46 PM
RudeLude95
21
09-22-2005 09:24 PM
