help with removing window trim and mirror 95 coupe
so my paint on the window trim is chipping and want to re paint it,so us my side mirrors theres over spray from painting my car and its all over the side mirrors.but how do you remove them without taking out the whole door internals.wanna remove them from the outside..lmk
Re: help with removing window trim and mirror 95 coupe
only way to get the trim off from the outside of the car is to break the clips. roll down the window and get a SMALL flathead screwdriver and gently pry the clips off. As for the mirror take of the cover behind it and remove two of the 3 8mm nuts. The last on u have to get with a wrench or remove the door panel. Once u brake these loose you can unscrew with your fingers 95% of the time
reefer_bob
12-12-2004 08:10 PM
