EG part questions! new to hondatech!
New User
so i have a 93 civic sedan LX, i recently swapped it out to a D16z6, with the p28. exedy stage 1 clutch, oem/stock everything else!. but nearly everything important on the car has been replaced.
http://img714.imageshack.us/img714/3...9955141819.jpg
http://img69.imageshack.us/g/9531150...955141819.jpg/
first of all, im new to this i've only have it for about 6 months, its also my first car. i would like to know..
Are coupe and hatchback hoods the same as the sedan?
How hard is it to do a front end swap with a hatchback or coupe? (f.bumper,fendors,head/corner lights)
Whats the best type of suspension setup to get without breakin the bank? I also want to be able to put 4-5 or people in it, and not scrap like a b****.
I also recently bought an Fm transmitter for my ipod, it works in all cars but my civic. anyone know why?
Oh look, I can change this
Re: EG part questions! new to hondatech!
Instead, use that $$ and invest in quality performance pieces or OEM parts (see my sig) or taking your girlfriend on holiday. Money and time much better invested.
New User
hey thanks for the help!
i know im not plannng on doing the front end swap unless all the pieces litterally fall into my lap.
yes my cars antenna works it picks up radio stations no problem.
suspension, i still need to get done, any suggestions.
and i have a friend with a coupe hood, so i will be throwing that on soon. i hope it fits!
But, if you insist, at least measure it before you put it on, to save yourself the time and effort of swapping. Then go to the junkyard or hit up Kijiji.ca.
New User
well i guess i failed to mention that its for a front end swap, i already have my headlights. so technically i only need to grab fendors, if the coupe hood will fit..
so deschlong.. i guess i just didnt mention that.. thanks for your help,
As mentioned you will need to grab fenders, bumper, and corner lights .... for it to fit properly. If you're not concerned about it fitting properly, then you should do as you please!
You said yourself that these pieces would need to "fall in your lap" for you to do it. But, then later you say all you'd need is the fenders? Because you already have the headlights? Confusing!
I think you would benefit from a little more research on this topic, to spare yourself some disappointment down the road: Here's a starter.
jdm_eggy
02-21-2012 09:03 AM
fryman
02-22-2010 11:44 AM
jadugartir
12-17-2007 03:46 PM
