Rear Integra Suspension..?
So i have done some research on this suspension swap for my 1997 Civic Si..
I have read that all you need to complete the swap is Integra e brake cables.. is this true?
Also, if that was to be the only thing i needed couldnt i just use the cables of the integra in the first place?
Is it true that the suspension off a 1995 Integra is a direct bolt up?
Any imput would be appricated.
Thanks in advance
Thanks in advance
Re: Rear Integra Suspension..?
hmmm do you mean you are doing a full brake conversion?? otherwise I don't see how the suspension and e-brake cables are linked..could be wrong..
can you explain exactly what you mean? what parts do you have from the integra and what exact swap are you doing?
IDK what market you are in but I was under the impression that the si was not released again until 99.But if you do have an si( unless it was stripped) then you should already have four wheel disc brakes. The integra rears will work but you should have to get em1 ebrake cables.
Lol Canadian Si 96-98 are Si, 96-00 SiG and 99-00 Are the SiR here haha
but yes i want to put integar rear brakes on my 1997 civic. Do the integra stuts fit the civic?
The integra brakes will work. however you will need to get a prop valvle from a 99-00 civic SI-R because the prop valve wont work. However the master cylender will work you will need to swap that also. you can find the prop valve here brand new unless you can locate one locally or thru honda tech
http://www.inlinefour.com/oemhoprva.html (pick the 99-00 Si)
and to Mach0 The Integra GSR brakes are larger in diameter than the civic SI brakes in the US and canada (Si-R)
to clear the air
Usdm EX = Canadian SI
USDN SI= Canadian SI-r not sure about the SiG
The GSR brakes are the Larges Dimeter brakes that came stock on a honda civic/Integra with out converting to 5 lug . So the largest 4 lug.
to clear the air
to clear the air
to clear the air
https://honda-tech.com/forums/showth...ake+conversion
you should find everything you need to know there. tells you exactly what you need and don't need and why
Hatchback_Pat
10-14-2012 10:16 PM
JayDM-hatch
11-21-2007 06:19 PM
