loss of power sputtering sound in eg?
i think it might be something with my fuel, maybe injectors or filter, idk for sure tho?
when i drive it it seems like its randomly loosing fuel, maybe fuel pump? any body
got any tricks to check with out having to pull fuel pump out or anything idk never replaced em befor.
no im not retarded for not knowing this (tired of hearing that) just never had this problem befor, thanks guys lemme know what you guys think,
Re: loss of power sputtering sound in eg?
-check resistance on your injectors, pump.
-replace your fuel filter that's a common problem as well.
-if resistance checks out okay then i'd look into your dizzy and check the rotor/cap.
-and if all of that is okay then i would pull the injectors/fuel rail off leave the injectors plugged into the rail/harness and check the spray pattern.
1990, 1992, 1996, 2000, civic, honda, integra, intermited, loss, power, random, si, spattering, sputtering
