Spark Issue
Old 01-25-2010, 07:53 AM
thereverendstu's Avatar
Default Spark Issue
I'm having a strange issue here. I'm only getting spark when the key is released after cranking. Any ideas?
Using a spark plug from an ignition wire and grounding it onto the negative battery terminal. I do not see spark while cranking but as soon as the key is released to it's run position there is spark.
Old 01-25-2010, 03:49 PM
d16soda's Avatar
Default Re: Spark Issue
did you test everything in the distributor? if not, check the dizzy cap, rotor, then move on the the icm, if everything checks out, check the coil.
Old 01-25-2010, 05:44 PM
Technical Hero
HondaPartsHero's Avatar
http://techauto.awardspace.com/ignition.html
Old 01-25-2010, 08:16 PM
civic_r87111's Avatar
Sounds like it could b a bad ingition switch, the contacts inside the switch wore out.
jakescakesz06
01-04-2016 09:38 AM
thangnhocngheo
10-10-2011 08:27 PM
AznBlueBoy
09-08-2006 08:21 PM
GoldCoin
08-21-2006 06:29 PM
Quick Reply: Spark Issue
