My civic sounds like a suby!
i got a 92 civic hatch D15B ..now my situation is my car when taking off from first gear or in between gears at low rpms it sounds like a subaru and there is a great amount of powerloss but then after abit it will clear up then it would back at normal before it starts to choke up again..i had this random guy driving next to me and yell out "Dizzy"..so now im looking at buying a cap n rotor...but before i do i jump on here first to if im headed in the right direction with this.
Re: My civic sounds like a suby!
Thats is hillarous, yet so kind of him.
Anyways, whenever a Civic ownered complains about his car sounding like a Suby, you have a misfire. Is your Check Engine Light On? You may be able to figure out which cyclinder it is if the corrosponding CEL is on. You may just have something as simple as a bad spark plug.
Hey dude just make sure to check the pressure on each cylinder. Check ur CEL. I had the same problem last year and turned out to be that i had bent valves... i had to get a new head.. GL
same thing happened to my friend check the injectors to make sure they are spraying. check by switching the coonnectors to the other injectors
I changed out the cap and rotor. I also had the Ignition Control Module check and it was bad and had it replaced and still having same problem!
supadupafast
04-19-2015 04:02 PM
92hatch_12
15
12-02-2011 11:46 PM
EL TYPE R
01-30-2009 04:19 PM
