Climate Control problems!!!
Old 01-26-2010, 12:08 PM
SHell_'s Avatar
Default Climate Control problems!!!
The car is a 1995 civic hatchback cx.
Everything seems to be working, but the problem is that whenever I use the climate control on the highest speed setting ( fan speed #4) the wiring harness for the Climate control (the white 6 pin one, not the green one) begins to heat up and smoke right where it enters the fan speed switch on the back of the climate control cluster! It works fine on all the other speed settings. But if i keep it on #4 it will surely burn up...
What does this mean? The car looks like it has had the blower motor replaced, and all of the wiring looks to be in order? Could this mean i have a ground missing or a short somewhere? What should I check???
thanks alot!
Old 01-27-2010, 08:08 AM
SHell_'s Avatar
Default Re: Climate Control problems!!!
anyone?
Old 01-28-2010, 09:57 AM
SHell_'s Avatar
tyler55
12-07-2011 06:42 AM
98greensi
10-13-2007 03:47 PM
tidrab
07-30-2004 08:10 AM
2k1_ITR_0736
06-19-2003 02:00 PM
rwcdrums
02-02-2003 12:52 AM
Quick Reply: Climate Control problems!!!
