92 civic blinkers won't work
I have checked all the fuses a million times and they are all good.
I went and bought a relay/electronic flasher for the turn signal too and i put it in and still have no blinkers.
i have a big meet this weekend and need to get this fixed before then, any help is appreciated, thanks
Re: 92 civic blinkers won't work
try replacing the multifunction switch ( your blinker switch) you have to buy the whole unit cause it controls your lights and blinkers i would start there if that doesnt work start tracing wires...possible broken wire
Oh look, I can change this
Have you tried swapping the hazard switch with a known good? Seems like an odd thing to go wrong, but it would be good to check. I know that the blinkers won't work without the hazard switch plugged in, and if the hazard switch is fouled, then nothing works.... so, good to try. Post back.
86RedFoxBodyGT
10-04-2011 04:36 AM
