B20Z SETUP?
Old 01-28-2010, 01:18 AM
SIR_APPROVED's Avatar
Default B20Z SETUP?
First of all not to sure if this is the right place for be posting it. But here I go.
Bought a complete 2001 B20 block for 300 bucks and planning on goin B20VTEC. First time trying it. And I'm goin to start working on the block first and the vtec head latter. But planning on using a B16 head. I know that the B20z already comes with a knock sender and a little more high compression then the older motors. But I want to go higher compression. Was wondering what's the best setup to be using. As in what pistons should I use? I need to know the exact specs and size of what's goo to use if thTs possible. I don't wanna F_ck up that's y. Thanks.
Old 01-28-2010, 03:57 AM
turbodcxbro's Avatar
Default Re: B20Z SETUP?
Go with the RS Machine ITR pistons in 84mm bore and you'll be set!
Old 01-28-2010, 04:10 AM
Sounds good bro. Wondering what's the compression ration on those pistons will be?
Old 01-28-2010, 05:01 AM
EKstallion's Avatar
https://honda-tech.com/forums/tech-misc-15/difference-compression-between-b20b-vs-b20z-460954/
A good thread to check.
Old 01-28-2010, 05:09 AM
Originally Posted by EKstallion
good thread. But I was wondering what would be the compression if I were to use the RS machine ITR 84mm pistons will be.
Old 01-28-2010, 08:48 AM
EKstallion's Avatar
Not sure. If a B20Z is 9.6:1 stock and the RS machined Type R pistons come with this information:
S Machine B20 Type R Piston *Specs based off 84mm Piston
Piston Specs
Data/mm
Top Land
.250
Step
.019
Dome Height
.100
Oil To Fill
12.2
Net CC�S
1.3
Compression Ratio Table : RS B20 Type R Pistons
Engine/Motor Type
Compression Ratio
GSR B18C
11.75:1
LS / B16
11.7:1
LS / GSR
11.9:1
LS B18A/B
11.2:1
B16
10.35:1
I could confidently say that you would be in the ballpark of 11:1
ben_art
13
12-02-2014 03:09 PM
blackeg
26
03-02-2014 05:57 AM
type_r_teggy
10
02-23-2009 08:28 AM
7rrivera7
29
01-11-2007 03:23 AM
Quick Reply: B20Z SETUP?
