Best way to remove exhaust manifold studs on '95 ex?
So I had a stud break on me before I even fully torqued the nut down...
Guess I can't expect everything to go smoothly on a 15 year old engine.
Half of it is still sticking out of the head but I was wondering if anyone on here had some suggestions on removing it. Are these things thread locked (Red) at all? Would it be better to put a Tap & Die set to use here or get some vice grips and get a good lock on the stud and turn in loose? And would it be best to try and remove it when the motors heated up or cold?
It's #22 on this diagram for some clarification:
Re: Best way to remove exhaust manifold studs on '95 ex?
try vise grips. or go get an easy out. should come out of the head pretty easy if not just put some heat to it. it happens all the time
1baddturbosi
12-10-2006 03:18 PM
Flamenco-T
05-21-2002 05:36 AM
