B series into Del Sol Pwr steering pump Help
Heres my issue, i have a 94 del sol that i am putting a b series in. The motor came out of a 99 ls. The problem is the power steering line on the car does not bolt onto the power steering pump. My question is, is there a pump that i can get that will work? Ive searched and concluded that a 95 integra pump will work, but i got one and it did not work. Thanks for any help.
Re: B series into Del Sol Pwr steering pump Help
the 95 teggy pump will work but you will need the p72 pump brackets for that pump,, the del sol b16 pump will work too but you will need either the P54 upper bracket or the P30 upper bracket...
I really appreciate the response, but can you break this down into lamens terms? What pump off of exactly what car? and what car do the brackets come off of? Thanks
No prob... basically all integra (B18B or B18C) uses the P72 pump,, it requires the P72 top pwr steering pump bracket,, If you use the B16a1,B16a2,or b16a3 pwr str pump, thats the P54 or the P30 pump, and will require either the P54 or P30 upper pump bracket,, All B engines uses the same Bottom bracket and its a P54 bracket.
I do appreciate the help. I do have one issue though. My issue is the line on the del sol has a different pattern than were it bolts onto the p72 pump.is there a pump that will fit on a b series motor but has the same bolt pattern as the del sol line?
Oh yeah, I forgot to mention, since you have a 94 del sol,, it uses the smaller hose inlet.. Im pretty sure your pumps hole is way too big for your line right? you need the 94-97 teggy pump or the 94+ del sol B series pump.. I have the pump you need if you are interested. but I only have the pump, no brackets. If you are willing to pay for shipping, I can even trade pumps with you..
It should,, but just to be safe,, what are the numbers stamped on your brackets, or better yet, does your pwr steering pump says P72 on the sticker? If you can, take a pict of your pump and send it to Madbusy168@yahoo.com
I can send you a picture, no problem email me at Madbusy168@yahoo.com so I can reply to your email with the picture.. thanks
Curlybandit
11-06-2017 08:18 AM
Flite
12-05-2006 02:59 PM
