Need Help!!!
Need Help!!!
I have a 2000 honda civic hatch and CEL is on. Its a P0420.
Everyone says to replace the CAT, but I took it to get tested and it passed. O2 sensors passed also.
I dont have any air leaks.
Ive changed spark plugs, wires, cap & rotor.
Still CEL is on.
I was gonna get the ignition coil tested...
Any help would be great.
thanks in advance
Still CEL is on.
thanks in advance
Re: Need Help!!!
The car is completely stock. Im not sure if anything has ever been replaced.
I took it to get smoged and it passed all the tests except for the malfunction indicator light test(CEL). btw i live in california.
I just got all the air leaks fixed. due to idle searching. Also cleaned the IACV.
Re: Need Help!!!
x2^
not the same code but i had a bad 02 sensor that set the cel off, satyed on after it was replaced for about 3 months until i finally hooked up my scanner and cleared it and it never came back on
Re: Need Help!!!
Just because an o2 sensor is bad does not mean it will fail emissions. It means you reading will be higher than normal, but it can still be within Cali's specs.
Resident Gearhead
Re: Need Help!!!
But just like anywhere else that has inspection, if a CEL (MIL) is on = automatic fail, which is what happened to the OP.
socalrocks
08-10-2011 07:43 PM
