h23 questions.
TRIAL USER
h23 questions.
im planning to swap this h23 into my 95 4dr civic. what all from a prelude will bolt on with little or no modification? im talking like axles and such. help?
Re: h23 questions.
There really isn't anything that will bolt on with little to no modification. You need to go look at the links posted in your other thread, everything is already written out for you. All modifications that need to be done for the swap are in there and the axle info is in the 1st & 2nd link (no, complete Prelude axles won't work). For the exhaust manifold and the exhaust, you're probably going to have to cut off pipe from your exhaust and weld on a new flange, or you'll have to add more pipe. The other option is to get an aftermarket exhaust system, and get something of correct length to go in between the header and exhaust; like a cat, a resonator, or a test pipe.
