Can you block the Fitv on a 95 civic?
Can you block the Fitv on a 95 civic? surging idle??
So my honda is having an idle problem only at cold start and it idle surges from 1500-2000rpms for about a minute and then sits at like 1800rpms until it gets alittle warm then it idles at normal 450rpms. So ive been hearing that the Fast Idle Thermo-Valve could be the problem, and i have also heard that you can block it off.
Any info on this would be great. Thanks
Resident Gearhead
Re: Can you block the Fitv on a 95 civic?
So my honda is having an idle problem only at cold start and it idles at 2000rpms until it gets warm then it idles at normal 450rpms. So ive been hearing that the Fast Idle Thermo-Valve could be the problem, and i have also heard that you can block it off.
FITV is supposed to raise the idle until the coolant warms up, then it closes and the IACV takes full control of idle air flow.
I meant to say it surges from 1500-2000rpms when its cold and only lasts like a 1minute and then its fine, just idles at steady at 1800ish rpms until the car gets warm
Resident Gearhead
Normal. It's trying to get warmed up.
BlackJacket
12-08-2013 10:07 PM
b20bFourDoorCivicLX
04-16-2013 08:34 PM
del_parker
07-22-2003 06:53 PM
