oil catch can????
oil catch can????
ok i have a question i am currently driving a 94 civic coupe Motor:
JDM B16A 92-95 SIR2 (170hp,113tq,10.4cr - Stock numbers / Actual numbers should exceed 200hp, but needs to be dyno tuned for accurate numbers)
1.6L DOHC VTEC
JDM OBD1 ECU chipped to run JUN Stage 3 Cams
LSD Tranny w/ GSR Clutch
and
Modification List:
JUN Stage 3 Camshafts
JUN Valve Springs
JUN Light Weight Flywheel
ITR Valves
Manly Retainers
ITR Intake Manifold
Ericks Racing Billet 68mm Throttle Body
Skunk2 Cam Gears
Port and Polish Head
Milled .30
Wiseco 11:5:1 Comp Pistons
Eagle H-Beam Rods
Golden Eagle Sleeves
Stock Bore
Stock Crank
New Honda Bearings
New ITR Oil Pump
Spoon Sports Thermostat
Mugen Fan Switch
Mugen 2 Layer Head Gasket
Vortec Fuel Pressure Regulator
MSD 8.5mm Wire Set
NGK Iridium Racing Plugs
AEM Short Ram Intake
DC JDM 4-1 Header w/ Thermo Tec Heat Wrap
my question is do i need the oil catch can? i just got a yowai ss type wp carbon intake and i know i am not goin to like how it is going to look with all tubes running everywhere over the intake system the guy who had the car before me put the catch can on there just a simple question thanks for any reply
1.6L DOHC VTEC
and
Modification List:
JUN Valve Springs
ITR Valves
Manly Retainers
ITR Intake Manifold
Skunk2 Cam Gears
Milled .30
Eagle H-Beam Rods
Stock Bore
Stock Crank
New Honda Bearings
New ITR Oil Pump
Mugen Fan Switch
MSD 8.5mm Wire Set
Re: oil catch can????
i don't think you need one..to be honest, i think oil catch cans are more for cosmetic purposes and for offroad vehicles. Either make your own or not have one at all, the amount you pay for a Cusco or branded one is not worth it for the amount of oil you'll be catching.
You wouldnt gain any horepower or anything but for all the compression you have there is tremendous crancase ventilation pressure but if you dont want all that going back into your motor. But some people seem to say if you re-use it its better for seals
RedheadRacing
03-05-2008 08:52 AM
civic99b16a
11-30-2004 03:38 PM
93egLSVtec
10
06-23-2004 01:22 AM
