having issues with motor swap
i am currently doing a gsr in to a 98 ex. i am having problems aligning the motor. i have the sides mounted but the rear is giving an issue. any suggestions? i have a rear ctr/si bracket or i think i do any help would be great as to i want to finish it asap. below is a picture of my rear bracket.
Re: having issues with motor swap
Does it connect properly to the engine itself? Where exactly are you having issues? Also, what driver-side mount are you using? Just eyeballing it, it *LOOKS* like it should.
I've attached the part diagram for the 99-00 Civic SI mounts. Does your bracket have anything stamped on it?
Sean
Sean
not that i know of. i'll be pulling the rear motor mount back out and see what the problem is. 99 si driver side mount. just rear alignment is problem.
GrimeyAssLos
11
02-27-2012 09:56 AM
AzntaggeR
02-14-2004 07:31 PM
crxhybrid1320
04-20-2003 07:00 PM
