Solid Rear Lower Tie Bar?
Old 03-25-2010, 11:54 PM
s13hero's Avatar
Default Solid Rear Lower Tie Bar?
I was wondering if anyone else besides benen and beaks makes a solid rear lower tie bar for EGs. I realize that there is a debate over whether or not they do anything at all, but I just want to know if any other company besides the two named above make any sold (non jointed) ones for our cars.
Old 03-26-2010, 03:12 AM
fastrxu's Avatar
Default Re: Solid Rear Lower Tie Bar?
There's knockoffs all over they don't have a specific brand.
One week they'll sell as ABC racing the next they will sell as 123 racing so jjst keep checking
Old 03-26-2010, 03:15 AM
fastrxu's Avatar
Old 03-26-2010, 06:27 AM
Jakessw's Avatar
I am in the process of making a lower bar for my del sol...
It actually bolts together the lower control arm brackets together.
No need to unbolt the control arm and risk breaking something...
I measured the hole up and to the middle of the car to use, it is 23.500" apart.
It is not done yet but will be installing the holes and painting sometime this weekend.
What do you think?
Old 03-26-2010, 06:39 AM
318 Curves, 11 miles
Vindicator9000's Avatar
What do you think?
Nice.... does that add any subframe reinforcement? Any plans to produce them?
OP, I'd consider the ASR piece. It's not exactly a lower bar, but it accomplishes the same thing as well as reinforcing the subframe.
Old 03-26-2010, 06:48 AM
Jakessw's Avatar
Yea it adds support/stiffness to the subframe buy connecting the lower control arm brackets together...
I would be pleased to produce them but first I have some research to do..
I need to install this one on my car, make changes accordingly..
and I would need some people who want to buy them...
Old 03-26-2010, 06:56 AM
blkcivic310's Avatar
id look into buying one
Old 03-26-2010, 07:15 AM
Jakessw's Avatar
Thanks, that would be cool to sell a few...
by the way this is technically still in development phase but
anyone have any suggestions?
If I were to ship them out blasted (no paint) like in the close up picture,
what does everyone think is a fair price?
The bar is torch-cut out of 1020 mild steel,
Then the spacers get welded on,
Then the bar gets pressed flat,
Then it gets shot blasted,
Then the mounting (clearance) holes get drilled on a bar machine using a program.
It is about 24.750" long x 2.125" tall x .750" thick (without spacers)
The mounting holes are 23.500" apart...
Old 03-26-2010, 10:01 AM
Jakessw's Avatar
The bar is done (minus paint)...
Here are more pics holding it up over the holes it will bolt to....
Old 03-26-2010, 10:08 AM
dpetro1's Avatar
do you not have a factory sway bar? most oem and aftermarket sway bars mount to that location. ive never had the inner lca bolts break. just the shock mounts.
to the OP, password jdm also makes a solid (no heim joints) bar.
Old 03-26-2010, 10:43 AM
burningrex's Avatar
i'd rather have sway bars that thing is just for looks...
op carbing also has one
Old 03-26-2010, 11:44 AM
alphalanos's Avatar
ASR brace. Its a brace on its own, and it allows to bolt up a swaybar. Cant go wrong.
Old 03-26-2010, 01:11 PM
mugen si's Avatar
X2
dth0ng69
Suspension & Brakes
12-11-2009 11:37 AM
The Collin
01-18-2007 08:27 PM
GG99
10-25-2005 12:28 AM
Blkcoupe
10-20-2002 06:40 AM
Synthesis
10-16-2002 12:48 PM
Quick Reply: Solid Rear Lower Tie Bar?
