Converting Automatic SOHC ECU to 5speed?
Hello i have a 1996 automatic d16 SOHC Ecu and I'm using it on my 1996 d15 5speed SOHC swap. I heard there's a way to reprogram the automatic ECU for Manual applications. Can anyone point me in the right direction?
Re: Converting Automatic SOHC ECU to 5speed?
p28???
the way i did mine was I THINK cut resister RP18
and jump RP17 or it might have been the other way around
what linked said is right but only if it's an OBD-I ECU. a 1996 should be OBD-II so unless you already have converted to OBD-I... you'll need to.
OBD2 ECUs, no, you can't. Well, you can chip them, but it's hard and nobody does it.
Just get a 5 speed EDU. Or better yet, get an OBD1 ECU and you can do whatever you like with it.
crxcess
09-14-2003 08:53 PM
