b16 compression numbers?
I got 175 psi across all 4 cyl,,,,,seems low to me,,,does anyone know wat my compression should be? Ran a compression test because its powerless,,, and bogs when vtec kicks in ,,,,
Re: b16 compression numbers?
could be something else
numbers are low but are they steady
my b16 i just rebuilt is liek afreak motor, 205 psi in every cylinder. i kept up with my boys 350z and smoke gsr teggy's
Jus did full tune up ,,, I bought the car like 1 month ago,,, I noticed the cam covers r str,,,,,so I'm wondering if the previous owner put low compression pistons or did motor work,,, jus trying to see wat the compression is supose to be??
some of them with 135 minimum go up to 199 psi. but i think you have nothin to worry about. especially since they are all the same. if you had more that 28 psi in the difference of any 2 cylinders then youd have issues technically. but if it were up to me i would say any mere that 10 psi difference is signs of issues. i'm just **** about that crap though
Its an 00 civic si b16a2 ,,,thanks for the input so far,,,, jus trying to figure out wats wrong ,,, I couldn't even keep up with a sohc civic,,,,
Capt. Jimbo McSubipants
02-21-2005 12:33 AM
Stinkalope
04-24-2001 09:04 PM
