eg turn signals wont work/ and hazrads contol the fuel pump
i put a b18c gsr in my eg hatch and my turn signals will not work but if i put the hazards button down then they just stay on constant. also then when i put the hazards down then my fuel fump will not go on when i turn the key. so im wondering if there is something that i have connected wrong. or something im really bad with electrical stuff. im uses a stock wiring harness and i have a chipped p06 ecu if that matter at all.
Re: eg turn signals wont work/ and hazrads contol the fuel pump
the hazard button is also somewhat connected to the ignition and it some what can make other things not function we had the same problem when we did a gsr swap in a crx until we used a different engine harness and it stop malfunctioning
there was a b series motor in my car before and then i put this one in there and now im having problems. also could the fuel pump not be turning on because there aren't enough volts coming out of my battery because i tried jumping my car and it work it started right up.
redbull99
25
04-26-2016 07:47 PM
andoshan
01-21-2016 12:27 AM
2ndcoming
07-01-2007 05:30 PM
