Fog light help
Fog light help
so i got these winjet fog lights for my em1...i found some instructions online and printed them but they didnt match the harness i have.....everything is pretty much wired in but the fogs dont turn on.....they came with a oem looking button to turn the fogs on or off...it lights up when i press it but no fogs
heres the harness
this white wire came with a brown plug that connects to the fuse box???
plug for the switch vv
i dont know why they dont turn on...everything is grounded
heres the harness
Location: Japanese Domestic Mutt, aka JDM, Conn., U.S.A.
Re: Fog light help
Those lights look like my Raybrigs except for their pretty amber color!
That harness is nothing like the OEM one but did you eventually tie it in to the factory wire near the fuse box? The other end is a brown connector and is tucked down behind your windshield washer fluid tank. If you did the inside correctly, that wire will be hot so get some type of light, attach the hot wire and then ground it someplace up front. If nothing happens then you have no juice getting up front and you know the problem is under the dash. If you have juice the is each light grounded up in the front? In the old days just being bolted to the metal bumper grounded them. I do not know if your front harness has a ground wire to the lights.
crazi92hb
27
07-14-2005 09:11 AM
95civickid
03-12-2005 12:43 AM
