check engine
check engine
Well I have a 92 honda civic hatch. I have a b16 with gsr cams 44occ 50 trim honda data p28/. the check engine light comes on when im on full boost and begins to jerk in and out off boost? Does anybody knows how can I go about fixing this problem? And also having trouble with the v-tech activating at times?
Re: check engine
you need to pull the code. if you have hondata s300 there is a tab that will show the code, if not jump the connector and pull the code the old fashion way.
maybe you are hitting a boost cut enabled by the tuner?
zachsbat1
04-24-2008 05:04 PM
