tps sensor not working?
Old 05-13-2012, 04:47 AM
Fnix's Avatar
Default tps sensor not working?
If my TPS sensor was bad would it not allow air into the intake manifold? I notice there is a passage in my TB that goes to the TPS sensor but dont know what is inside of it.
Old 05-13-2012, 05:00 AM
Resident Gearhead
BryanM.'s Avatar
Default Re: tps sensor not working?
I think you are referring to the IACV, the idle air control valve.
Which engine do you have?
Old 05-13-2012, 05:05 AM
Fnix's Avatar
d16y8. my car only stays on if I hold onto gas pedal, so at idle it dies, so i figured the tps isnt letting air in
Old 05-13-2012, 05:21 AM
Resident Gearhead
BryanM.'s Avatar
The TPS just measures how much you are stepping on the throttle pedal. The throttle cable is what moves the throttle plate, not the TPS.
That's smells like a IACV issue.
Old 05-13-2012, 05:26 AM
Fnix's Avatar
My car was working good and then I removed my IM and cleaned it up, just unplugged the hoses and electrical connector to the IACV and now it's giving me these problems, I dont know what could have happened. I'll clean it and then if nothing guess I'll buy a new one.
If I unplug the IACV electrical connector on normal circumstances the car would stall at idle correct?
Old 05-13-2012, 05:33 AM
The Grumpiest
grumblemarc's Avatar
Maybe it's a vacuum leak? Double check your work and make sure you didn't switch something around or break anything by accident.
Old 05-13-2012, 05:44 AM
Fnix's Avatar
already checked for leaks, on the flipside the only way it idles without dieing is if i remove this cap. Bringing me to think it has to be the IACV now since it is not getting air at idle. These two have always been capped btw and worked fine before.
Old 05-13-2012, 06:02 AM
Resident Gearhead
BryanM.'s Avatar
Is there a CEL? If so, what is the code(s)?
Old 05-14-2012, 08:21 AM
Fnix's Avatar
I took the iacv off and cleaned it, there was not any coolant in it or the hoses yet because i Havent let it bleed all of the air out yet... Would no coolant to the iacv cause it to not let air into the IM?
my car currently is open headers inside of a small garage and if I let it idle for a while the neighbors will call the police...
kootari
02-10-2007 04:07 PM
nutball72
11-11-2006 07:14 PM
nutball72
08-26-2006 11:09 AM
prendi
17
04-29-2003 07:38 AM
soHybridized
03-13-2002 10:22 AM
Quick Reply: tps sensor not working?
