98 Civic radiator fan not working
Old 05-10-2012, 01:52 PM
hammer1's Avatar
Default 98 Civic radiator fan not working
I have a 98' cjvjc, the cooling fan was not coming on I hooked it up to 12volt source and it came on. I replaced the relay and it worked once and will not come on again. Suggestion?
Old 05-10-2012, 02:55 PM
Ej8-Hulk's Avatar
Default Re: cooling fan
your engine bay is probably not hot enough for the fan to come on.
Old 05-10-2012, 02:57 PM
The Grumpiest
grumblemarc's Avatar
Default Re: 98 Civic radiator fan not working
How do you know it isn't actually working? Is the car overheating?
Old 05-10-2012, 04:16 PM
Retired Moderator
EsotericImage's Avatar
In4moarinfo
LOLZ @marc's sig
Old 05-10-2012, 04:46 PM
AKHAN420's Avatar
Cut the plug off and wire it up to a toggle switch and turn it on before u drive
Old 05-10-2012, 04:49 PM
The Grumpiest
Do not do this hack job. Fix it properly so it works properly. I hate hack jobs. Shows a total lack of respect for your car.
Old 05-10-2012, 05:09 PM
hammer1's Avatar
after replacing the relay the fan went on once. i turned the car off restarted it again, let it idle and the fan would not come on when the engine started to get hot
Old 05-10-2012, 05:11 PM
The Grumpiest
You didn't answer. Does the car actually overheat?
Old 05-10-2012, 05:14 PM
hammer1's Avatar
the car overheats
Old 05-10-2012, 05:28 PM
Former User's Avatar
Is coolant low in the radiator or reservoir?
Have you bled the cooling system?
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push/turn the dash heater lever/**** to MAX heat. Fan need not be on.
3) Follow the directions in the diagram below
wildbill_52280
13
06-26-2017 04:37 AM
Tdawg_1993
06-30-2015 04:33 PM
chrisalvar
01-29-2012 05:15 PM
Aalewyn
07-09-2011 09:20 AM
spidermancivic
05-05-2009 09:07 PM
Quick Reply: 98 Civic radiator fan not working
