Engine Warning Light, Limp Mode & Bluey Smoke!!!
The engine warning light comes on after a few minutes of driving and it goes into limp mode and seems to puff out bluey, white smoke. However, it only puffs out this smoke when the engine warning light is on and the car is in limp mode.
Took my car to a garage and they did a Diagnostics Test and they came back with the error of throttle response sensor. I relpaced this with a whole new throttle body- easier and cheaper- and also changed the lambda sensor just in case but no luck. The garage said they had a hard time communicating with the ECU. I've also tried resetting the ECU.
Any ideas welcome!
Any ideas welcome!
Re: Engine Warning Light, Limp Mode & Bluey Smoke!!!
Is all of this mess the result of a recent swap?
If it is research your particular swap more and correct some things.
maybe he did have a hard time communicating with it lol, as this is a plethora of crap codes, baro sensor should be integrated into the ecu so dont think thats servicable but dont quote me on it,
To be honest my first attemp at this would be using a known good ECU!
crank fluc sensor is obd2 correct me if im wrong, the one behind the crank pulley.
From what I understand, blue smoke indicates burning oil. White smoke/steam could be evaporated coolant or fuel vapor. Black smoke would indicate a rich condition.
I would also put in a known good ECU; I'd also adjust the FPR to stock specs if it can be done. Easier to diagnose what the car is supposed to be doing than what YOU want it to be doing.
Last edited by UrbanDiplomat; 05-06-2012 at 09:35 AM. Reason: additional information
Yeah. The fact is, you don't know if the ECU in there right now is any good or not. That being the case, you'd be hard-pressed to determine whether or not anything else is doing what it's supposed to be doing.
I'm not familiar with what a chipped P28 is supposed to look like, but found this: http://www.hamotorsports.com/socketedp28.html
That's not what yours looks like. In any event, I'd just replace it to have the piece of mind.
That ECU is definitely not chipped. At least "the guy" didn't lie to you about it being a P28.
Start off by resetting your ECU, and finding out which codes come back after the reset.
what the hell kind of setup is this? d16A6 vtec? or d16Z6? and your throwing a CKF code? but you showed us a P28 ecu? ya ok bud...
yes sorry it is a d16Z6 also the Warning Light light come on when in on idle after about 3 mins and the cars runs a bit lumpy
So you purchased this car not knowing what exactly has been done to it? Just that it's swapped? Most likely it's a hack job, and the car needs to be re-done correctly from scratch. Start there.
How is that picuture supposed to help us help you get the car running right. First, become educated on the parts installed on your car. Get a working ECU that matches the engine in the car.
Darth CRX
04-29-2014 07:33 AM
