apexi N1
apexi N1
What is the difference between this muffler the universal one and the non-universal one.
I need it for my si.
Also how would i know which is which.
thanks
thanks
Re: apexi N1 (sshaikh01)
universal muffler is just a muffler that you weld to your stock, or custom made exhaust piping. the non universal youre reffering to is probably the cat back system, that replaces the whole exhaust system after the catalytic converter.
Re: apexi N1 (Btown_99Si)
go catback. you'll be happy with it. the universal one has a bigger canister than the catback system so it will look funny. and you have to get it installed by a muffler shop
If i get a muffler which is non-universal which is just a muffler how can i tell ?
and can i put it on my stock piping ?
Re: apexi N1 (Kid1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid1320 »</TD></TR><TR><TD CLASS="quote">that is called the axle back. where you should be able to bolt right up to the rear section of your stock B-pipe</TD></TR></TABLE>
How much does the axle back run for fair price used ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid1320 »</TD></TR><TR><TD CLASS="quote"> the universal one has a bigger canister than the catback system so it will look funny. </TD></TR></TABLE>
that is incorrect, the universal canister is smaller than the catback canister.
Re: apexi N1 (ej1civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej1civic »</TD></TR><TR><TD CLASS="quote">
that is incorrect, the universal canister is smaller than the catback canister.</TD></TR></TABLE>
ok the one i saw was probably the "turbo" universal muffler then
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid1320 »</TD></TR><TR><TD CLASS="quote">go catback. you'll be happy with it. the universal one has a bigger canister than the catback system so it will look funny. and you have to get it installed by a muffler shop</TD></TR></TABLE>
whats wrong with building a custom exhaust system??
Re: apexi N1 (purek9hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purek9hybrid »</TD></TR><TR><TD CLASS="quote">
whats wrong with building a custom exhaust system??</TD></TR></TABLE>
nothing, except most people run w/o a resonator and it sounds like a fart can.
You have over 3000 posts and you don't know the answer?
YOU POST *****!!!
Universal is smaller and just a muffler.
The other is a catback and has a huge tip.
I think the universal is also availbable in different colors...
YOU POST *****!!!
i just put the Apexi n1 catback on my 99 si today i paid 500 brand new
it sounds bad ***, it was worth the 500 it.it has a big canister and a 4.5 in.
tip it also comes out with a little of an angle looks great
get the catback spend the money
did i say there was anything wrong with it?
Modified by Kid1320 at 2:38 AM 4/16/2003
-get the N1 catback, I have it on my 00si and I like it. I have a DC sports cat-back on my 91 crx, and I think it is too quiet. Get the N1 cat-back
Location: around the corner to the left ... no, your other left
Re: apexi N1 (Lucky925l)
the n1 catback exhaust is great. it sounds nice and i noticed some gains on my 00 si. the universal canister is smaller and i dont believe they sell a universal turbo canister. the only problem i had was that the piping comes really close to the gas tank. i have heard about people with problems concerning the piping hitting the gas tank and making noises. the exhaust actually looks better on hatchbacks. they tilt more at an angle. the only problem with that is that the piping goes under the control arms in the rear and it tends to scrap alot if your car is dropped to much. go with the cat back.
Re: apexi N1 (ricancivicsi8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricancivicsi8 »</TD></TR><TR><TD CLASS="quote"> the universal canister is smaller and i dont believe they sell a universal turbo canister. </TD></TR></TABLE>
WRONG. For one, I owned the A'PEXi N1 Turbo universal muffler. Secondly, is it that hard to visit the manufacturer's homepage? http://apexi-usa.com/exhausts_...s.asp
Re: apexi N1 (Daniel)
156-A003 N1 Universal Turbo 80mm inlet (Canister & 115mm Tip)
156-A008 N1 Universal NA 60mm inlet (Canister & 90mm Tip)
apparently the turbo is bigger
Re: apexi N1 (JDMH22HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH »</TD></TR><TR><TD CLASS="quote">Actually, it just depends. Some of the catbacks come with the smaller muffler and some come with the bigger, it just depends on the application. Also, as for the universal it comes in differents sizes as well.</TD></TR></TABLE>
Correct. For the universal Apexi mufflers, they make a slim design (N/A) and a huge design (FI).
I have a 2.5" custom catback w. a shitty muffler, should i just change the muffler or get an apexi n
comptechgsr
08-02-2001 03:05 AM
