ek tein flex users: what dampering setting are you guys using?
Old 12-10-2003, 05:18 AM
jeremy.'s Avatar
Default ek tein flex users: what dampering setting are you guys using?
curious to see what you ek drivers are running on the streets....0 being the hardest. i'm running the standard 8 front and 8 rear right now until the springs start to settle...
Old 12-10-2003, 06:12 AM
thinkbrianthink bu's Avatar
Springs settle when you put the car on the ground.
There is no transition period. If they 'settle' anymore after the initial compression then its called 'sagging'.
Old 12-10-2003, 07:41 AM
jeremy.'s Avatar
Default Re: (thinkbrianthink)
sorry that's what i meant
Old 12-10-2003, 09:06 AM
R you serious's Avatar
Default Re: ek tein flex users: what dampering setting are you guys using? (ek_jeremy)
run what ever feels best. i personally like a little bit of a stiff ride, so i keep it on 8/8 on the street and kick the rear up to 11 for the track.
Old 12-17-2003, 02:17 PM
moto27cm's Avatar
I run about 8 all around on the street. On the AutoX course, I run the back all the way in (16) and the front at about 12.
Old 12-17-2003, 02:56 PM
Damon B.'s Avatar
Default Re: (moto27cm)
right now I', runing 10/10...
Old 12-17-2003, 06:53 PM
blackspoonem's Avatar
Default Re: (CleanSi)
I run 8 all around feels good in my civic
Old 12-17-2003, 07:30 PM
WangChung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">curious to see what you ek drivers are running on the streets....0 being the hardest. i'm running the standard 8 front and 8 rear right now until the springs start to settle...</TD></TR></TABLE>
i have no experience with teins, but from the other guys suggestions, "0" sounds like the softest setting, 16 being the stiffest.
crashedacar
02-15-2008 09:44 PM
macsmurray
15
02-27-2005 06:11 PM
IS3Fifty
07-07-2004 12:38 PM
VTEC-DA
22
08-27-2002 06:17 PM
Quick Reply: ek tein flex users: what dampering setting are you guys using?
