ABS from a ITR
ABS from a ITR
Can the ITR abs system work on a 94 ex coupe that has GSR rear disc conversion? what is all that is needed? My friend has an ITR Abs system that he is willing to ell to me, but he nor I knows if all the necessay peices are there.
Re: ABS from a ITR (Ateyour2JZ)
are you sure that you want abs? cause you will need a lot of parts that came of your friend car, abs ecu, proportional valve, axles with speed ring, abs system.... ect. ect. but hey if you wanted bad enuff then go for it . imo
Re: ABS from a ITR (2lua)
I started a thread on a similar topic about a year ago. You may find it helpful:
https://honda-tech.com/zerothread?id=349392
