Chipped Ecu question
I jes chipped my ecu and it redline at 10000rpm. Is it safe to shift at like 9000rpm? What would happen if I do. Cuz i have done it twice and iono if it will blow something.
Re: Chipped Ecu question (a2nvi3tboy)
I would never set the rev limiter that high in any of my vehicles just in case I'm not paying attention like I should. But that's just me.
does your car make power up to 10,000 rpm? can your motor handle 10,000 rpm? if so, then yes you can shift at 9,000 rpm if you want.
listen here,
i drive a motor that is close enough to built
and it makes power up to approx 9800k so i shift around 9500, couple times i think i went pass 12k didnt hurt a damn thing,
but if i were you rechip the chip and set it at 8500 once u known that your head is well built then set it at 9k, your motor have to be producing alot of power if you want 10k rev limiter and strong parts titanium, steel those will do,
well heres what its got,
this is whats in the rex
B18a block
Golden Eagle Sleeves
Golden Eagle Bore
Machined
JE 86mm Pistons High Comp
Shot Peen rods
Head
Spoon Type R head
Titanium Valve Springs retainers
Skunk2 Stage 3 Race Cams
Port n Polish
ARP head studs
Cosmetic 2layer head gasket
4-1 Headers Stainless Steel 2.5 collector
B16 Tranny equip with LSD Quaife
Ran on the following slicks 24s/12s 14inch 22s/10s 14inch and 20s/8s 14inch
yep it was strong enough to push the 24s at 6psi
on a crx full interior nothing gutted
ran 12.2s@112mph street driven we got a higher top speed with the 22s/10s 14inch
is it safe for you to shift at 9k ? is your head built ?
if not there goes the bent valves or a hole through the side walls of the block
Modified by Miles85916 at 12:15 PM 12/12/2003
B18a block
Golden Eagle Bore
Machined
Shot Peen rods
Head
Spoon Type R head
Port n Polish
ARP head studs
Re: Chipped Ecu question (SOHC_MShue)
most likely your allready vary lucky it hasn't blowen
just you asking the question makes me believe that you have no idea what your doing and FOR SURE should not be reving ANY stock motor to 10k. I wouldn't even rev a stock s2k to 10k. It's just stupid anyway because your not going to be making any power
Re: Chipped Ecu question (Miles85916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miles85916 »</TD></TR><TR><TD CLASS="quote">listen here,
B18a block
Golden Eagle Bore
Machined
Shot Peen rods
Head
Spoon Type R head
Port n Polish
ARP head studs
Modified by Miles85916 at 12:15 PM 12/12/2003</TD></TR></TABLE>
Uhm... ok....
Don't rev that high unless you make power that high and your motor can handle the revs.
B18a block
Golden Eagle Bore
Machined
Shot Peen rods
Head
Spoon Type R head
Port n Polish
ARP head studs
Uhm... ok....
1 Post
as what everyone has said already..its not smart to rev past stock the stock rev limit, unless your motor is really built to make that kind of power in that high of rpm......lower the rev limit for your own safety....
Re: Chipped Ecu question (AzSi22)
umm maybe you should read more about golden eagle, and what i got in the head, then you'll maybe figure out why i have power band up to like 9800k i can shift at 10k but it power drops, like around 9800k
whyd u think someone corrected me dumbass, its been a long day for me and when i type i just type so now you can quit being a dick and get on with your life..
i drive a motor CYCLE that is close enough to built
thats what u really meant right?
CheckMyFitment
10-14-2013 07:17 AM
