my car died... im home and not my car... tell me wat u think.
well while the ignition key is turn to ON... nothing lites up... which if u turn it to ACC at alittle angle off the ON position it lites bac up.. or if u turn alittle angle to START then it lights back up... i can start it and hold the keys towards START and the engine runs fine.. but letting it go back on to ON position then it shuts down completely. i know its the ignition inside the key somewhere.. do you guys know anything or whats its called so i can buy the piece for it? is it some kind of coil that is worn out and not being shorted to keep the power on..?
Re: my car died... im home and not my car... tell me wat u think. (Hvy P)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hvy P »</TD></TR><TR><TD CLASS="quote">yeah , it's the ignition switch</TD></TR></TABLE>
i THINK he means the ignition lock cylinder. u can pick one up and it should come with a new set of keys. good luck
Re: my car died... im home and not my car... tell me wat u think. (Grimace EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimace EJ6 »</TD></TR><TR><TD CLASS="quote">
i THINK he means the ignition lock cylinder. u can pick one up and it should come with a new set of keys. good luck</TD></TR></TABLE>
does it come with the doors, trunk.. etc? the key wholes....
Re: my car died... im home and not my car... tell me wat u think. (wizzards581)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 »</TD></TR><TR><TD CLASS="quote">
does it come with the doors, trunk.. etc? the key wholes....</TD></TR></TABLE>
I doubt it...then you would have to replace all of those locks as well. You could take out all the tumblers, but then you could open them with anything (but as long as you don't tell anyone it should be all good)
Re: my car died... im home and not my car... tell me wat u think. (Ricey McRicerton)
or you could just have two different keys i did with my older civic it wasnt a big problem
Re: my car died... im home and not my car... tell me wat u think. (EGh22aEG)
Ignition switch connects to the lock cylinder. You can unhook the ignition switch from the lock cylinder, stick a screwdriver in it ,start it, and see if it still has the same problem. I bet it will.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hvy P »</TD></TR><TR><TD CLASS="quote">Ignition switch connects to the lock cylinder. You can unhook the ignition switch from the lock cylinder, stick a screwdriver in it ,start it, and see if it still has the same problem. I bet it will.</TD></TR></TABLE>
yes i seen GSRs that got jacked and those things fall in two pieces. which they use the screw driver to start it. so its the ignition switch which doesnt concern the key pattern is the piece i will need to change? my bro called honda and they said i need the whole thing which is roughly about 200... i dont think its a big problem jus to fix it is it?
Re: (Bunz)
cant be the starter. i can drive my car in first gear while holding the keys angling towards the START but if i let go off to the ON then everything shuts off blank! no lights... unless its been angled towards START or ACC... cant stay in the middle of ON...
Moderator
Re: my car died... im home and not my car... tell me wat u think. (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">its your ignition.</TD></TR></TABLE>
si senior
si senior
Morag
05-21-2017 10:12 AM
liljohnson
08-12-2004 11:48 PM
