Will I run into any problems (besides inside tire wear) if I don't have a camber kit?
1 Post
Just wondering, the car was slammed when I got it (on coil overs) and the dude told me he didn't put a camber kit on the car. He said he just got his tires rotated every oil change to balance it out. If I do need one, which is the best camber kit to buy?
Re: Will I run into any problems (besides inside tire wear) if I don't have a camber kit? (CivicSwap
You definitly need a camber kit, not only does all that negative camber wear tires quickly but it also adversley affects how your car handles.
Just so you guys know...incorrect toe setting will destroy tires quicker than camber wear.
1 Post
yeah, i figured there was more negative than just the tire wear. Can someone tell me what the best camber kits are? Like give me good, better, best so I have some options.
1 Post
im looking at the Skunk2 camber kit but the description just said for the front ($225.53). Dont I also need a kit for the rear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BseriesPWR »</TD></TR><TR><TD CLASS="quote">You definitly need a camber kit, not only does all that negative camber wear tires quickly but it also adversley affects how your car handles.</TD></TR></TABLE>
sorry, but you are completely wrong. negative camber is generally beneficial to your cars handling capabilites - up to a point. negative camber does eat away at your tires a little bit, but not nearly as much as a nonzero toe setting.
get an alignment and set your toe to 0, and you'll be fine. the only reason you'll need a camber kit is to run a specific degree of camber, or if you're real **** about tires.
also search this forum for camber kit. a thread just like this pops up every week (i actually made one myself not too long ago).
1 Post
so if i make sure my toe is set to 0 and just rotate the tires every oil change I should be straight? I'll get a good camber kit eventually, Id just rather put some $$ into the engine right now.
yeah you'll be cool. don't believe me?
https://honda-tech.com/zerothread?id=695138
https://honda-tech.com/zerothread?id=696481
https://honda-tech.com/zerothread?id=674615
https://honda-tech.com/zerothread?id=663584
https://honda-tech.com/zerothread?id=663200
https://honda-tech.com/zerothread?id=640594 <-mine, turned out pretty good
https://honda-tech.com/zerothread?id=563096
man there's like 1000 more. if you want more evidence search this forum's archives for "camber kit"
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">yeah you'll be cool. don't believe me? </TD></TR></TABLE>
yeah, thanks man. Now I can take that camber money and throw it into the engine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSwapper »</TD></TR><TR><TD CLASS="quote">
yeah, thanks man. Now I can take that camber money and throw it into the engine </TD></TR></TABLE>
Hell yes...always a good thing to hear!
CAMBER IS WAY OFF!!!!!!! which camber kit well fix this ???????????? BEST CAMBER KIT OUT THERE??????
Kangolbrand
Suspension & Brakes
17
03-30-2006 02:15 PM
pr0phet
11-22-2005 03:59 PM
