help with o2 signal wire
have a 2000 honda civic. need to know the color wire going into the ecu for the o2 signal wire cuz i dont want to have to hook it up under the hood, mainly cuz i dont know where a hole in the fire wall is. if anyone can help. thanx
Re: help with o2 signal wire (deathscythe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deathscythe »</TD></TR><TR><TD CLASS="quote">have a 2000 honda civic. need to know the color wire going into the ecu for the o2 signal wire cuz i dont want to have to hook it up under the hood, mainly cuz i dont know where a hole in the fire wall is. if anyone can help. thanx</TD></TR></TABLE>
I'm confused, you don't want to have to hook what up under the hood...your o2 sensor, its supposed to be hooked up under there.Are you hooking up a A/f Ratio sensor, thats the only other thing I can thing of. Also a hole in the firewall is easy to find. Just trace your wireharness. You might have to do a little trimming to the rubber grommets though. Please clarify this a little better, becuase your not being too clear or i'm just burned out from working all day and going to school at night.
Re: help with o2 signal wire (allmotorEG-SI)
i need to know what the color of the wire is on the ecu that is the signal wire going to the o2 sensor because i dont want to run the wire for the a/f ratio gauge into the engine. im sure the signal wire on the o2 sensor is white..but what is the color when u reach the ecu.
I don't have a manual but if you have a continuity tester use that and test the white wire to the ecu plugs and see which one has continuity.
SPOON_BeIgHtEeNsEe
03-03-2008 03:26 AM
89dohcEF
20
12-07-2003 02:07 AM
