B18B1 into EK coupe
B18B1 into EK coupe
Ok well swap is done, I am pretty sure I got the wiring done ok.
I am using a P2E ECU and a EX harness. Both obd2
I am getting code 1 and 14, O2 1 and IACV.
I have the IACV plugged into A12 right now and I know the o2 is plugged in right, And I am pretty sure the IACV is ok. The only plugs i have left out are IAB, Vtec, Vtec oil pressure, and Knock.
I cannot reset these codes. If I remove the fuse they stay on and if I remove ground from battery it doesnt reset.
MY question is this. are the OBD2 code and OBD1 codes the same? Or do I have to get a code scanner? I am lost on this now. Would I have to change any other plugs at the ECU pinout? I originally had a B18C1 in the car do I have to switch some wires back to the original?
Any help would be great. TIA
inline4
07-27-2006 03:04 AM
