what comes first, shocks or tires.
Old Member
bad shocks cause damage on tires. Now damage tires cause shocks to be worst. I need to change both. Unfortunately no place can do both at the same time (unless I want to pay their $$$). Plus $$ is tight as is with all of us. So may need to shop around and wait.
What should I do first? Shocks or tires?
Re: what comes first, shocks or tires. (GoLowDrew)
all depends on how bad they both are...
If your ties are bald and treadless, then tires first...
If your tires are drivable then shocks first...
somethings, this included, are common just common sense?
Re: what comes first, shocks or tires. (Grimm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoLowDrew »</TD></TR><TR><TD CLASS="quote">bad shocks cause damage on tires. Now damage tires cause shocks to be worst. I need to change both. Unfortunately no place can do both at the same time (unless I want to pay their $$$). Plus $$ is tight as is with all of us. So may need to shop around and wait.
What should I do first? Shocks or tires?</TD></TR></TABLE> exactly what i was going to say
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm »</TD></TR><TR><TD CLASS="quote">all depends on how bad they both are...
Unceasing Measure
Re: what comes first, shocks or tires. (hanson said)
Tires are usually cheaper than shocks, and much easier to install, so I'd go with that first if it's not horribly prohibitive.
Old Member
I should also include that the tires pretty new. The damaged rear shocks damaged only the rear tires where there are bumps now on the surface. The bumps inturn cause unnecessary compression to the shock. So the shock is thinking I'm on a bumpy road all the time.
I could do tires first, but then the bad shocks will damage my tires. If I roll on the bumpy tires, I would wear out the shocks.
SingleCamin
08-10-2009 03:21 AM
