94 Del Sol Headlight Q's
My friend has a 94 del sol and his lights went out recently. so he went to shucks and bought the regurlar bluish light bulb he always gets. When he puts the bulb in, it turns out yellow. He thoguht it might have been the defected bulb so he went out and bought 2 more blue bulbs but the headlight still turns yellow like stock. the passenger side headlight flashes blue, but the driver side is OEM yellow. Anything wrong or anyway to fix this problem? thanks
by flash i ment, when the headlights are turned on. we tried and looked for loose connections. but dont know what its yellow, we switched around the bulbs and its just teh driver side
When does the headlight flash ? when you signal ? Maybe the wires might be crossed with the siganl lamp. I've had a similar problem (dim light) where it turned out to be a bad connection at the back of the headlight, I'd recheck the wiring maybe with a multi-meter see if the output is correct.
Re: (dohcdelsol93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolSiR »</TD></TR><TR><TD CLASS="quote">When does the headlight flash ? when you signal ? Maybe the wires might be crossed with the siganl lamp. I've had a similar problem (dim light) where it turned out to be a bad connection at the back of the headlight, I'd recheck the wiring maybe with a multi-meter see if the output is correct.</TD></TR></TABLE>
by "FLASHING" i meant when the lights were just turned on. when we turn on the headlights, the driver side is OEM yellow, and the passenger side is the blue bulbs he had bought.
This all happend after he blew a bulb on the driver side.
there are 3 wires thats connected to the black box bulb am i right? dont know which one is bad of if that is the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 »</TD></TR><TR><TD CLASS="quote">make sure he's buying the proper part # bulb</TD></TR></TABLE>
9003 is the right bulb right?
the 1 and only jj
09-25-2009 03:17 AM
reddysol
09-23-2007 10:42 PM
