car bogged then ....wont start again
well i was driving to pick somethings up for my car ...daily routine..got in myt car started it let warm up a bit and then left the house.... weel drove for about 5mins and the car kind of miss fired,i didnt think nothin of it so i kept driving..When stoopped at the stop sign, it still seem fine.as soon as i gave it gas it kind it started to boog really bad and my car started to shake and idle wierd..well i pulled over .and it was fine again til i gave it gas again so i pulled over again .shutoff the car ,then the car just cranked popped and backfired some...well i bought a new dizzy and still nothin just cranks..
Motor: JDM D15b OBD-1
Car: 93 eg HB
Car: 93 eg HB
Re: car bogged then ....wont start again (jdmEFnine1)
I sounds to me like the fuel pump, I would check and make sure you are getting the propper pressure to the fuel rail, if you don't have adequate pressure the fuel won't atomize and your car will not run. Good luck.
Re: car bogged then ....wont start again (saywhat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saywhat »</TD></TR><TR><TD CLASS="quote">I sounds to me like the fuel pump, I would check and make sure you are getting the propper pressure to the fuel rail, if you don't have adequate pressure the fuel won't atomize and your car will not run. Good luck.</TD></TR></TABLE> yeah thats what i was thinking it could be fuel pressure or fuel filter got clooged with something
Re: (TypeRWanter)
ive Been doing everything else to my car .but fix that problem..give me time to fix cosmetic things.and get things straight..this is next on my to do list ..cause im going to need my car up and running again
Re: (jdmEFnine1)
I would take off the intake system, spray a little starter fluid or carb cleaner down the troat of the intake manifold while a friend trys to start it, and see what happens. If the car starts, stumbles, then dies it is probably your f/pump. if the car won't start at all, it is probably timing or spark.
ttcheung97
08-24-2020 06:31 AM
teg racer 877
04-07-2010 09:53 PM
akteamster
13
01-22-2006 09:00 PM
