LCA compatibility? suspension swap ?'s
i am pretty sure this will work but figured i'd check anyway.
i have a 93 del sol si on tein ss dampers. i plan on picking up a 96+ hatch and swapping the teins from the sol to the hatch. i know that the 96+ LCA are different [slightly narrower where the strut mounts up]. same issue that arises with the Megan LCA's in pre 96 cars.
anyway, are there any other fitment issues with the LCA if i planned on swapping the LCA from the del sol [or better yet, purchasing aftermarket LCA's for a 92-95 civic for the 96+ car?].
i believe everything else will both right up correct?
i just don't want to do the "washer" deal...
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: LCA compatibility? suspension swap ?'s (chris c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris c »</TD></TR><TR><TD CLASS="quote">are there any other fitment issues with the LCA if i planned on swapping the LCA from the del sol [or better yet, purchasing aftermarket LCA's for a 92-95 civic for the 96+ car?].</TD></TR></TABLE>
the 92-95 civic and del sol rear lca WILL NOT work on the 96-00 civics. sorry bro.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris c »</TD></TR><TR><TD CLASS="quote">ijust don't want to do the "washer" deal...</TD></TR></TABLE>
sorry, but i think you are stuck with it, short of buying new suspension.
Electrician
Well, on the EG platform, it's a bit wider than that of the EK. If anything, you'll need to grind down on the bushing a little in order for the EK ones to fit.
mrsean008
20
07-25-2015 04:16 AM
summerof2008
03-06-2009 09:30 AM
TRYLSTEG808
01-05-2008 12:11 AM
skip122
02-15-2007 12:07 PM
deadlock32
03-02-2006 07:36 PM
