NEED major help with ba16a in 92 eg
everything is goin great except for the wiring, we have the b16 wiring harness, but it looks easier to just clip the plugs ang soder to the old harness???? any ideas??, and any info bout how to match the plugs if we cut and resoder?, and we'e need to run some independant wires( vtec selniod, vtec oil pressre) any more we neeed to do?!?!?! thanks for any help u can give , we need to have this done by sunday
Re: NEED major help with ba16a in 92 eg (ridexstraight)
i used the stock cx wiring harness and ran vtec,knock,and o2 sensor wires back to the ecu is was fairly simple that way. all of the plugs on the cx harness will plug into the b16 motor. Using the jdm b16 harness proll is going to be a pain because all wires go to the driver side shock tower
when I put mine in I just did a lot of searching on here and found all of the info i needed!
HT Order of Merit
Re: NEED major help with ba16a in 92 eg (alexb16hb)
First off, you shouldnt have started this without a clue about the wiring.
Second, use your stock wire harness off your old motor. Use a helms manual to figure out what plugs go where, but most of them should just line up correctly. The ones by the intake manifold and throttle body are hard because they all use the same plugs. You will have to add three wires, VTEC, VTEC Pressure and Knock Sensor. Use the harness the motor came with to get the correct plugs, and run the wires through the firewall to the ECU.
If you dont have a HELMS manual, GET ONE. Much easier when you can look at wiring scematics.
Also try here... http://hybrid.honda-perf.org
Memnoch
12-12-2007 08:05 PM
fcuked
12-29-2003 06:44 PM
