water temp?????
water temp?????
does anybody know were the cluster reads water temp from. i have a civic with a type r motor. when i take the motor to around 8k the temp on the cluster goes straight to H. but the aftermarket guage i have hooked up directly to the radiator stays at 150F. just wondering if the cluster is reading from somewhere else that really is getting hot from coolant not circulating so the guage on the radiator stays cold
tried changing the thermostat, didnt make a difference
Re: water temp????? (hott95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hott95eg »</TD></TR><TR><TD CLASS="quote">Coolant temp sensor mean anything to you?</TD></TR></TABLE>lmao, indeed. It should be located on the side of the head.
Re: (ctownintegra)
the sensor for the aftermarket ga. is on the oppisite side of the drain plug.
you said your hose was plugged. did you have the same problem? was it the upper or lower radiator hose
JBBNJ609
Honda Civic (2001 - 2005)
06-29-2012 11:07 AM
