KYB Mounting Question
I am a (Trial User) Army
Hey,
So how to I mount my new springs onto KYB AGX's? I'm assuming I use the perches from my stock shocks?
Thanks,
George
Thanks,
George
Re: KYB Mounting Question (litterbox)
you can use a coil over system like ground control wich is designed for use with kyb's
or you use your stock springs and they "should " fit on there...
Re: KYB Mounting Question (bushfreakz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bushfreakz »</TD></TR><TR><TD CLASS="quote">you can use a coil over system like ground control wich is designed for use with kyb's
or you use your stock springs and they "should " fit on there...</TD></TR></TABLE>
My setup is H&R sports and KYB AGX's. I already have these parts. I just need to know what other parts I need to mount them. Yes, I know I will have to compress the spring. But can someone clarify that I can just use the perches from my old stock suspension?
Deano_D aka "Brick Top"
Suspension & Brakes
10
12-16-2005 09:59 AM
Attoir
03-07-2004 04:47 PM
